Timing info
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
dirtydon
Just upgraded my 72 521 with ei dizzy, Can anyone tell me the correct way to time my l18. Do check timing with vacuum advance with connected or disconnected? The service manuals that I found online don't mention anything other than the timing spec.
Thanks in advance.
Dan
DanielC
    I believe that the distributer vacuum port is above the throttle plate at idle, so it should not matter if the distributer vacuum line is disconected, or not.
    I have the factory service manuals for a Datsun Pickup, Model 521 series chassis and body, Model L-13, L-16, and L-20 engine, and the Emission control system, 1970-1971.  The manuals also make no mention of discommecting the vacuum line.
    When setting the timing on my engine, I used the factory setting as a starting point, and then advanced the timing until I heard spark knock on hard acceleration.  I knew that was too much advance, and retarded the timing about 2 degrees from that point.  Running the timing as far advanced as possible without spark knock gives you the most power, and the best fuel economy.
    DO NOT LET YOUR ENGINE KNOCK!  It will hurt it, and it will cost you a lot more money to rebuild your engine, than you would of saved from fuel expenses.
    If you do not want to take the time to find the optimium timing for your engine, just set it to the factory recomendations.
dirtydon
The Vaccuum port is below the throttle plate and gives max vac at idle.
But thanks for the info.
Dan
71-521
time it with it connected.
dirtydon
I will try that, thanks again.
Return to “Datsun Chat”
