GA240 »
https://forums.nicoclub.com/ga240-u15149.html
Sat Jun 26, 2004 10:05 am
WELL, Ive got a little down time. My buddy dropped my idler sprocket and it has a hairline crack in it. So hes buying another one before I put it back together. When you say 9 and 12, you mean 9 on intake and 12 on exhaust right? My chain does not have but one mark on each chain. I bought an ebay timing kit for $140. I counted what it was and am planning on just putting it back the way it was. Main reason Im going for this is because I got a baseline dyno last week and it was 129hp/140tq so I figure it is working ok. (if it aint broke, dont fix it.) This timing replace is a HELL of alot more than I expected. Pretty much a teardown/rebuild with no bearing replacement. When my "odd" color mark on the crank pulley is at the needle, the crank key is pointing straight up. the mark is about 5:00. And the cam gears are as I stated above. (11:30/2:30) I should be okay right. These hp/tq numbers look about right?
I really dont think that my timing would be off from factory. Would it? It doesnt seem that anything has ever been tinkered with.
