Timing guru's.... please help
blues14
Car: 1995 Nissan 240SX GTS-t
I have an 5 speed rb20det that was originally an automatic. i know that a 5-speed rb should have timing set at 15 degrees, but my 5-speed is running off the original auto ecu which should be set at 20 degrees. i had my timing set at a shop to 15 degrees and i have a 'stutter' at 5k rpm, but if i advance my timing with the cas , the car loses the stutter. Is it safe to just advance it till it loses the stutter? its advanced by about 6-8mm right now.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I ran mine at 20deg cause I had the Auto ecu too. Didn't hurt anything at all.
