Timing Guide part #'s
Mitchum
Car: 2000 Dodge Dakota
1995 240SX
I searched through the SR parts guide and called my local nissan dealer today and the Part numbers i used were no good. Maybe there different in Canada?
Im under the impression a 90-99 SR20DE sentra timing set will be the same? So i guess if anyone can give me an SR20DE sentra VIN# to order with or the direct part #'s for the ALL the timing set (minus tensioner and chain) would be awesome.
thanks guys
Hijacker
Car: '92 240sx Convertible
'94 F-150
the p/ns in the parts thread are japanese but they are crossover number to the NA catalogue. They are good numbers as i've used them. I suggest calling a diff dealer, but if you must use that dealer, the kit is the same as a sentra se-r. JIC you need thye p/ns
Timing chain Jan 1991 - Dec 1998 13028-53J03
Chain guide slack side Jan 1991 - Sep 1996 13091-53J01, 13091-2J200
Chain guide slack side Sep 1996 - Sep 1997 13091-2J200, 13091-2J201
Chain guide slack side Sep 1997 - Dec 1998 13091-2J201, 13091-2J202
Chain guide tension side Jan 1991 - Oct 1997 13085-53J00, 13085-1N500
Chain guide tension side Oct 1997 - Dec 1998 13085-1N500
Timing chain tensioner Jan 1991 - Dec 1998 13070-2J200, 13070-2J203
Cam sprocket (intake) Jan 1991 - Dec 1998 13024-53J01
Cam sprocket (exhaust) Jan 1991 - Dec 1998 13095-52F00
Mitchum
1995 240SX
Unfortunately there the only Nissan dealer within 2 hours. I'll try those sentra numbers and if they don't work I'll look for a bigger dealer to contact. Thanks!
Hijacker
'94 F-150
If you can ship from the states, call some of our sponsors like Midway Nissan and Courtesy Nissan. Courtesy is one f the best dealers I've had to deal with and they can get you just about anything you want. They're in Texas, so I don't know if they'll ship that far north.
