Djuhnk »
https://forums.nicoclub.com/djuhnk-u168242.html
Sun Oct 03, 2010 12:03 am
bent valves.. in the process of finding the timing the valves i must have f'ed them up. checked the compression before i tore the head off for the second time cylinder 1- 50 lbs, 2- 0 lbs 3- 25 lbs, 4- 25 lbs, i cant believe it was even running...
first of all, i took off the head and it wouldnt have taken a teenage girl to know that my valves were bent. there was a huge gap just looking though the intake and exhaust ports.. so i happen to have another head laying around with perfect valves as far as im concerned, switch out the valves and slap the head back on with the same timing where it was running before i took it off.. started it up and it didnt run that well. switched the timing around 1 tooth to the best running postion and checked the compression.. cylinder 1- 100 lbs, 2- 0 lbs, 3- 50 lbs, 4- 100 lbs. it runs and idles now, but not nearly as well as it should.... i am completely baffled because i know these new valves arent bent. its just so irritating. i even sprayed some starting fluid in the intake side ports just to check, and all the valves were water tight.
if anyone can help me at this point it would be very appreciated, otherwise i am just going to run it like this... i have spent over 40 hours on this thing and its pissing me off
