Timing fixed... But I have to partial throttle at all?
newdude1
So I got my timing all worked out thanks to a few people. So onto my new problem, I started my car up idles great. I let it warm up then tried giving it a lil rev. Its all most like from idle to 3k its bogging and sounds like its missing especially if I hold it in that area. Now if I give it a little more gas it revs easily and smooth. Sounds really good. I have a z32 maf, 740cc injectors, s15 turbo and jwt ecu tune. What can cause it to bog down and miss between idle and 3k but still allow it to rev smoothly if giving a little more gas?
Modified by newdude1 at 7:19 AM 9/21/2009
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Take a multmeter and meacure the voltage output as you slowly go from idle to full throttle. It should be a nice smooth increase, but sometimes a particular spot wears out.
newdude1
Where at? The tps?
newdude1
Well I checked the TPS. Im getting .47 when closed and 4.16 at wot. That ok?
Also Im getting 12 volts to my maf. Right now Im trying to find someone in my area that is running on so I can test it.
But any other ideas?
Modified by newdude1 at 11:17 AM 9/21/2009
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Those numbers are fine, but what I was talking about was watching as you go from high to low to see if there is a jump anywhere in the middle.
newdude1
Just checked it and it goes up smoothly. No jumping around at all. Im still trying to find someone around me that is running the same maf but Im having no luck with that.
Anything else I should check?
One of my friends suggested it might be the tune, which I would be really pissed if it was. You guys think that a Jim wolf tune would cause this?
Chris28
Car: 92 s13 KA-T
Is your timing set correctly? I know the cam was off a tooth, but what about the CAS? (or distributor, not sure what sr's use for spark timing) My KA did that same thing before I got it timed with a timing gun, at light throttle it would hesitate a little bit. Driving was fine, it was only when there was no load.
Also check for vac leaks.
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
Perhaps the Z32 Maf is faulty. Is it used or new? try cleaning it up a bit.I went thru 2 Mafs just to get my SR run/idle right. My .02.
newdude1
Yup it was a bad maf. Thanks everyone for the help.
Steady_One_S13
