timing cover
big monkey racing
Car: 1990 240sx
does have the torque specs for the timing cover and all other bolts when doing a timing chain
x240xdrifter
Car: 1991 Nissan 240sx
ummm yes their is torque specs for the timing cover and all other bolts when doing a timing chain, be sure to follow them to a T, as it could damage that block, head and yadda yadda yadda
trusts14
Car: s14
hard enough where it wont leak and not so hard you break a bolt.
big monkey racing
Car: 1990 240sx
do u know where to find them
x240xdrifter
240sx FSM, they can be found here, just use the search functionAlldataMitchell on demandmaybe the guys at your local auto-zone, napa
big monkey racing
Car: 1990 240sx
alldata and mitchel are nice but r exspensive
Vegascorbin
Car: 1990 240sx dirt track race car
x240xdrifter wrote:240sx FSM, they can be found here, just use the search functionAlldataMitchell on demandmaybe the guys at your local auto-zone, napa
I did a search and all i found was Flywheel Specs. What search term will I find them under?
Also the FSM available from the web site in the sticky at the top of the page is NOT a FSM it is a re-typing/copy of some parts of the manual with NO diagrams etc. also no Torque Specs listed.
Next????
LayNLow240
Car: 92 240 coupe
Valve and front cover just hand tighten them. anything more and you will strip the threads out. i would say about 10 ft-lbs
x240xdrifter
LayNLow240 wrote:Valve and front cover just hand tighten them. anything more and you will strip the threads out. i would say about 10 ft-lbs
in-fact, come to think of it, I think your front timing cover is 14 ft. lbs. , not 100% sure, but i just rebuilt mine about 1/2 yr ago, and I think its 14
