No guarantees, but yeah it should work. Looks identical to the one I just pulled off my KA24E. If you need a new timing kit, the least expensive one I've found is sold by HM Performance and was $60 shipped after plugging in the coupon code HM1 at checkout. It even came with the fuel pump gasket, distributor o-ring, and the front cover crank seal (most don't come with this stuff).
http://store.yahoo.com/hm-perf....html
An easy way to figure out if the two front covers are the same is to go to an auto store's web site and see if the part number matches for both applications.
Hope that helps,Matt
