nizmo240sx_22 »
https://forums.nicoclub.com/nizmo240sx-22-u15466.html
Tue Apr 12, 2005 8:01 am
Be as careful as you can not to drop the oil pickup bolts in the oil pan.....if you do you'll be fishing with a magnet or droppin the crossmember to get the oil pan off. I've done it twice without removing the oil pan it's just the most time consuming part of the project. Good luck..
Try putting something under the bolt so it doesn't drop.
