scarboroughdub »
Fri Sep 09, 2005 5:30 am
hey guys i myself have been building and tuning cars for years but never nissans so i never had to deal with the timing issues ecu presents. most cars that i worked on had either a crank position sensor using 30-1 or 60-2 teeth or a hall effect sensor with single or 4 slots for spark firing.
well with the nissan i am aware that it uses a 360 slot disk in the distributor to get its 4 timing points but this presents a problem to me. since there is 360 points and monitoring the signal line its only shows a constant voltage to wich cannot be used to show a firing mark on many standalone or piggy back systems other than the aem and greddy units.
now the reason i ask is because i dont want to go the standalone route but i would like to use a different manufactorers piggyback system but i need to over come this timing issue.
any idea's would be helpful, ive got some wacky ones that may work but i want to hear yours.
i am aware of the aem ems, greddy units and all the reporgrammed ecus that are available i just want to see if we can make this a broader field.
