timing control, i need a little help ( Noob )
The All Mighty KA-T
Car: 1995 Eclipse GS-T
ok guys.....i dont have a tuned ECU to control my timing on my ka24de-t, and i know that for every psi you puch you need to retard your timing by 1 or 1.5......how do i do this?
is there anything out there that i can control my timing with?
Florida240sx
Need to fix your wastegate problem first. Then if you stay at the 7-8psi your stock timign is ok. After that you need to get a btm or ecu/piggyback. you could also turn your distributor to retard it. But you need to fix your wastegate first.How in the h3ll did your engine not go poof? Have you done any research what so ever? What is your setup?
The All Mighty KA-T
Rebuilt garrett t25ssa manifold3inch turbo back exhaustintakerb20det maf480cc injectorswalbro 255 fuel pumpapexi safc
PhuckTheSR20
You shouldnt need to retard the timing if you do the following.......
1. Run low boost at all times.2. At times you run high boost, make sure your A/F is RICH! And I mean REAL RICH.
The All Mighty KA-T
and why do i need to run it really rich....i have a wideband 02 to tune it.
PhuckTheSR20
Because of detonation issues. Plus you're on a stock engine. You dont want to shatter a piston do you? or bend a rod do you?
The All Mighty KA-T
sounds like a plan....thanks guys
Jookmasta
safe would be 11.0-11.5.............no need to run richer than that........and yes u could also use an msd btm to control timing.
Florida240sx
I live dangerous running 12-12.5 Hey it's mine.......But 11.5 is good safe number to aim for decent power and safe.
Chezedik
Car: 1991 Nissan 240sx
Seriously, if you retard base timing, you will be seriously disappointed with your power. Also, if you were to pull just 1 degree per pound, you would be at correct base at 7 pounds, but -7 at idle. Leaving lights would be lackluster. (A little alliteration makes the lesson linger longer - HA!)
