Touchdown038 »
https://forums.nicoclub.com/touchdown038-u3917.html
Thu Feb 26, 2004 1:19 pm
The car will start if the distributor timing is off a tooth, I just reinstalled my oil pump with new bolts last week and I ran into this same problem.
What you gotta do is put the engine at TDC, pull the distributor and oil pump w/ shaft, line up the two marks on the oil pump and shaft, reinstall completely straight and then install the distributor. The rotor should be at about 5 o'clock pointing at plug wire #1. Takes all of 20 minutes. Hope this helps, and good luck.
