On my 1978 280Z I have had to pull the timing case cover. Now would be a good time to replace the timing chain if it needs replacing. How is the wear-out determined on the timing chain? That is, how does one determine if it does need replacing?
I did not want to move the engine from the present position that it is in. That is, I don't want to turn it any because I have marked the position of the distributor and don't really want to change it's present timing (it was ru8nning excellent at that position). So, I really don't want to replace the timing chain unless it's needed.
The engine has 113,000 original miles and I think the chain has never been replaced. I have read that this chain should be replaced every 30,000 miles or so. Is this true? If so, it's way overdue.
