Timing Chain .....too much play?
High_Octane
Car: 1996 Q45 Pearl White
I have a 1996 Q45. While I was changing the valve cover gasket on the right side, I noticed more play in the timing chain "tc" then I would have expected. I am not sure what is an acceptable amount of deflection in the tc between the camshaft cog wheels. In the attached picture you can see the tc with 1/3 of an inch between the chain and the guide. Is this normal or acceptable for a Q45 with 150K miles. I removed the valve cover and top timing chain cover and visually inspected the guides. I did not notice any significant wear and the tensioner seems to be working. The tc appears tight on the left side.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
That's normal, but your engine could use some BG Quick Clean on your next change, an Envirolution engine flush, or a regimen of high detergent oil with frequent changes, or all three.
High_Octane
Thanks Brian! Great Advice!
Yes, the picture shows just how dirty things are inside my engine.
Where can I get BG Quick Clean?
Is an "Envirolution engine flush" something that is done in a repair shop...... or is a product that I can purchase?
Any recommendations on oil usage? I recently started using Castrol Fully Sythetic 5W-30. I have been changing the oil every 4-5K miles. Should I change it more often and/or use another oil after doing the BG Quick Clean.
5zigen
BG Quickclean can be purchased at http://www.everythinginfiniti.com
I believe Envirolution Engine Flush is something that can be done at a shop.
And last of all, yes, you should start doing 3k oil changes with Mobil 1 especially with an engine as dirty as yours
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
High_Octane wrote: 1.) Where can I get BG Quick Clean?
2.) Is an "Envirolution engine flush" something that is done in a repair shop...... or is a product that I can purchase?
1.) If Joe doesn't have it, try Ryno Performance Products http://www.ec-securehost.com/R....html or even eBay.
2.) It is a service. http://www.envirolution.com
Call Tom Mackin to find a shop near you.
(253) 639-1589 Office
(206) 550-2914 Cell
[email protected]
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
BG has a similiar machine flush as well as a new DIY purge.
http://www.bgprod.com/products/engineoil.html
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Yes dirty... I'm not sure about a '96 but with no oil pressure there will be slack.
You don't have VVT, so I don't know if this is a huge difference from '90 up.
