spoolthis »
https://forums.nicoclub.com/spoolthis-u15800.html
Sat May 01, 2004 4:46 pm
Hey there. I'm new to the 240 myself, but over the last few weekends I just did a timing chain R&R on my sohc. It's a pretty big job, but I got 'er done.
The noise going away seems odd, but it seems like the guide breaking off could change the sound but not make it go away completely.
Wishful thinking, but I think you may end up needing to do the chain/tensioner/guides. The lifters clattering may be a sign of low oil pressure, just above the light's threshold maybe. After I got mine back together there was one lifter that took quite while to bleed itself out. It's good now even cold.
My rig only has 114k on it and I found big chunks of the guide in the pan and shredded bits matted all over the pickup screen.
I should probably change my oil again soon to make sure the rest of it's out of the system.
Anyway, good luck with it. I've rambled too much.
