timing chain
PhaneSoul
Car: 89 Nissan 240SX SE Black 5spd Wrecked
95 Nissan 240SX SE Green 5spd s14.5 yay!
i got the tick, is there any saving the motor now? and how long do i have b4 it poops out
89 240
s13sr20chris
yeah, you can prob save it. how handy are you with a wrench? you got skillz?
PhaneSoul
did my own clutch, tie rod and lower control arm change, and sum work here and there, do tell, do tell, the sooner the better, i just dont want to lose this car, its the most important thing i have left..... well 3rd most....
180fan
Car: 89 fastback
you can do it. have a copy of the FSM handy, a pry bar, 27mm socket, some allen keys, 10/12/14mm sockets, RTV, some oil and coolant, and a pair of pliers and you should be good to go.
DO however, study notes that people have posted on the timing chain job. On the E, the biggest PITA I encountered was with the line up of the oil pump and distributor. Otherwise it's a very straight forward and pretty easy timing chain job. Good luck.
s13sr20chris
180fan wrote:you can do it. have a copy of the FSM handy, a pry bar, 27mm socket, some allen keys, 10/12/14mm sockets, RTV, some oil and coolant, and a pair of pliers and you should be good to go.
do some research, have all the tools and fsm, and start working. once you are about knee deep in uh-oh just post you probs and we will help you.
PhaneSoul
this is weird, was driving to work today, with my car playin tick tick tick in the background, well i hit a bump and when i came up to the light i listened and i couldnt hear the tick tick ticking..... And before it was loud, i mean u could stand 20 feet away and hear the damn thing. got off work tonight, started it up, got out, listened, and u can only faintly hear it now, just faintly, and some of my power loss has come back (yes it had a power loss, u floored it in 2nd and it felt like u were in a dodge spirit.... im beggining to wonder if it was an oil clog, because when my friend borrow the car, it started and he put a quart of oil in it and it shut up, but just for a little bit.... hmmm, well ive only drivin the thing a total of 4 months, but owned it for a year this febuary, and i dont know when the last time the oil was changed (on my things to do list for when i get money), i mean im jumping for joy on the outside because its not ticking as loud, but the inside of me is just scared to all hell
s13sr20chris
could have been a lifter. i reccomend an oil change and then shortly afterwards another oil change.
PhaneSoul
well i will try that my next paycheck. something came to my attention today, i was hanging out w/ a friend of mine and he mentioned he put a bottle of lucas fuel injector cleaner in my gastank the other day. i believe it was that same day that the car started ticking, and the next day it lost id say 1/4 of its power. today when i got on the highway i ran it up to redline in 3rd gear to catch up to the speed limit, and it rose in rpm's rather slowly and didnt want to go past 5200 rpms's, kindve like there was sumn clogging an injector or two. could my ticking, and the power loss be connected, maybe a case of a cylinder not getting any or little fuel into the cylinder, then the ticking from an igniting sparkplug that is lighting nothing?
s13sr20chris
possible but not too likely. i would chalk that up to coincidence. if the fuel additive was causing a prob it would most likely start in one cyl and give you a misfire type of problem. this could be anything like a chunk of carbon that got lodged in a valve or the rings.
PhaneSoul
how hard would that be to fix?
benemorius
Car: s13, s13, eg, e36
Dunno about the loss of power, but I can assure you that with the hydraulically-adjusted valve lifters that the ka uses, low oil means LOUD valve tapping. That may be what you're experiencing.
PhaneSoul
it could be low oil, but the weird thing is, after the really cold weather hit, i havent heard it.... but who knows, the tapping could be from oil, and the loss of power could be from a fuel injector clogged, after i put another tank of gas in, ive gone thru about 3/8ths of it and ive got some of that power back so...... we will see soon
s13sr20chris
cold weather=more oil pressure=maybe the lifters or chain tensioner is working better
maybe
PhaneSoul
heh, maybe, how much u think i could sell my car for?
s13sr20chris
ill give you $100 for it in virginia
