Larry Pengilly »
https://forums.nicoclub.com/larry-pengilly-u12500.html
Thu Feb 05, 2004 5:38 pm
you dont tighten them up, you have to replace them if they are stretched. if your chain were to skip a tooth you will probably end up doing a cyl head rebuild as well as replacing the pistons, if the valves hit them. these engine are interference engines, and it has to be right or things will hit.
your cause of the loose chain is probably due to the worn guides and tensioner, but if you tear down the engine that far to replace them you might as well replace the front main seal, chain upper and lower, both tensioners, all guides, that is really the only way to make severe chain rattling go away.......
have you tried to run a thicker oil, like a 15w50 when mine just started to make noise, I switched to Mobil 1 15w50 and it does two things, #1 it will clean all oil passages and anything that runs on oil pressure (due to the additives in synthetic) #2 a thicker oil will also slightly increase oil pressure. helping the tensioners push harder.
But most likey it is the chain being streched or a guide broken or missing....
later
