timing chain
1989240sx
Car: 1989 240sx and 1974 duster
hey guys i have a 89 240sx all stock the car has 159,000 i was wonder if i should replace my timing chain at all some time while it is in park the rpm will do up and down also when it is at a stop light it wil stumble like it want to die almost but it doesn't if you guys have any ideas other than timing chain let me know about it thanks
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
If the motor doesn't have that infamous rattle at startup, there's no need to replace any timing chain components.
As far as the hunting of the idle, check for a sticking EGR valve. If you haven't done a tuneup lately, do one.
destroyyourmind
Car: 89 240sx hatch ka24de. 91 240sx hatch.
check your maf sensor wipe it off other people on here have talked about it fixing there idling problems. I dont even have a maf on my car and it idles real rough
480sx
Car: 1996 Pearl White 240sx
destroyyourmind wrote:check your maf sensor wipe it off other people on here have talked about it fixing there idling problems. I dont even have a maf on my car and it idles real rough
First off, you dont want to touch your maf sensor with anything. Those things are super brittle and will break in a quickness. Use MAF sensor cleaner spray and follow the directions on the bottle.
Second, you mean your running your car without a freaken MAF? Those things arnt something that can just be discarded as some kind of unnecessary car part lol.. So you like driving with a 2500 RPM limiter, getting terrible gas millage, ect?
destroyyourmind
haha yeh it idles rough but its not to bad I'm getting one when I get some extra money
Nismo240driver
Car: 93 S13
clean your egr valve might be sticking as mentioned earlier but your IAC could be goin out if it only happens when your at a stop a.k.a idling... is what i believe i got out of your post.....tuneups help but leave the timing chain alone unless you hear the oooo so famous "marble in can" noise.....and destroyyourmind....get a MAF with whatever money you have dont wait....case closed.
1989240sx
where would the iac be at can not find it in the book
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
The IACV is located on the passenger's side of the engine, near the back, below the intake manifold.
dnlx5
Car: 91 240sx s13 hatch 5speed sr20de (crashed but still driving)
WAIT first check for vacume leaks they happen alot on 18 year old cars. my favorite way to do this is get a can of carb cleaner and (being wary of fire hazards0 spray all the vacume lines if the idle jumps up that means carb cleaner got sucked through a hole in the vacume system when i had a kae my intake gasket broke and that was the problem so spray your intake gaskets as well
dnlx5
hey i got a single cam maf for sale shooot me an e mail
1989240sx
hey guys does anyone have audio of a car when it timing chain is going out
jetroy240
Car: S13, AE86
many possibilities, I'll check first for codes, egr port gallery restricted or plugged w/ carbon deposits, secondary ignition (cap,rotor,wires,etc),or it might need additional grounding for maf sensor(common problem if u got injector code or O2 code).
