VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Wed Apr 23, 2025 9:21 pm
Nope, B is the bank1 tensioner and C is bank2. Main chain tensioner should be 13070-1MR0A. If you're doing all three chains then you'll want all three tensioners, if you're leaving the cam chains then you only need the main tensioner. All the VQ's I'm aware of have no gasket between the front and rear covers, they all use Nissan "gray death" which is a hybrid RTV. Permatex Ultra Gray is an almost exact equivalent and much cheaper. The two gaskets you positively want to replace while the main chain is off are the oil gallery gaskets on the rear timing cover. The factory Nissan gaskets aren't great, but CZP, Z1, and some others make composite steel gaskets which are very superior. Leaks in the gallery gaskets are a slow and often-undetectable death because it oil-starves the IVT's and mag-draggers at low RPM, but won't turn on the oil lamp until the leak is bad. Note that the aftermarket gaskets usually have their own torque spec which differs from OE.
