BadMojo »
https://forums.nicoclub.com/badmojo-u5205.html
Fri Aug 26, 2005 6:28 pm
Easier than swapping a motor. As for price, I'm not exactly sure. You'd probably be looking at somewhere in the $300 range for parts. Upper timing chain, lower timing chain, both lower chain guides and the two appropriate bolts, lower front cover gasket and tensioners. Probably would want to get new valve cover gaskets too. Since you'll need to drop the oil pan and pickup, you might want to replace the gasket and o-ring there too, but maybe that's extraneous.
The "kit" that Courtesy Nissan used to sell included a new water pump, thermostat, crankshaft oil seal and water hose. Unless the chain chewed through the pump assembly, I believe all of this stuff falls under "good to replace while you're in there" but not necessary unless worn.
