timing chain slack???
inkslingers13
Car: 1985 Corolla Gt-S
okay so i just got my motor back together, when i turn the motor from the crank bolt and a wrench, in between the cam sprockets gets a little slck then it goes away after it turns over. normal? or bad? i need to know ASAP so i can get the oil pump and stuff back together. please no bashing just gota know. thanks
inkslingers13
anyone? i have to know tonight so i can get it back together. and if it is bad, how can i fix it?
garagelu
Car: 1995 240sx w/ sr
on my sr, at TDC my timing chain has slack in it. I did everything right too. My sr has been running for a year and not one problem with it.
inkslingers13
thanks!!!!
Hijacker
Car: '92 240sx Convertible
'94 F-150
Give it more than 10 minutes before you start bumping please. Especially when it's 12:30 eastern tiem.
inkslingers13
it was not a bump hijacker, it was me adding to what i had to say. and me being impenitent. my bad
lostinatsugi
Car: 1990 c33 laurel w/sr20det
It'll should be fine once the tensioner gets oil pressure.
