huntin5L »
https://forums.nicoclub.com/huntin5l-u3755.html
Tue May 08, 2007 11:21 am
Well i am going to do the chain job, now since it is off by two teeth i just need to set the motor to tdc, which i have and the cam gear's keyway is facing straight up, which is correct right, and the then also line up the crank gear's keyway and just match up the silver links to the corresponding marks on the teeth of the gears and i should be all set right? I should also then set my distributor so it points to the #1 plug, correct? The only problem i forsee is getting the crank bolt off without moving it once it is set to TDC.
Modified by huntin5L at 3:53 PM 5/9/2007
