Timing Chain replacement
formalyDSM
Car: 1989 240 SX with An RB20
any of you guys or girls know if there is an easy way to do a timing chain replacement job on a 1989 240sx with a KA24E motor. rather than taking the entire front of the car apart or taking the motor out? let me know what you can come up with.
180fan
Car: 89 fastback
the sohc needs no such crap and fail. look over the procedure for the SOHC, not the DOHC.
btw, if you do plan on doing a chain job, for the most part, the front of the motor does come off, regardless of SOHC or DOHC. Just a difference of hours if the oil pan needs to drop or not.
