Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Tue May 20, 2003 8:00 pm
Replacing the timing chain is not an easy or fast thing to do. It involves quite a bit of work. As a result, I don't recommend doing it unless it's necessary.
Which leads to the next question, when is it necessary? Well, the timing chains don't exactly have a replacement interval. If yours is not making any noise, which is typically a rumble or ticking from the front of the engine upon startup and idle, and the engine runs fine, then don't worry about it. It will cost you anywhere from $200 to $400 for the kit, and then give yourself a good 3 day interval to do the job.
If you are really curious, pop the valve cover and the front sprocket cover off and see what the chain/guides/tensioners look like. You won't be able to see the whole assembly, but you will see the upper chain, sprockets, upper guides and upper tensioner (if I remember correctly). Excessive wear or slack in the chains, or score marks on the covers, will be a clue the chains probably need to be replaced. That's the one nice thing about chains...they will usually give SOME warning when they need attention. A belt will just go quietly into that bad engine-destroying night. Hope this helps...
