pauldfixr »
https://forums.nicoclub.com/pauldfixr-u253852.html
Sun Nov 20, 2016 8:02 pm
A few weeks ago, we took our 2004 Quest on a 300-mile round-trip to central Pennsylvania.
On the way out, all went well, but the next morning, some trouble started to loom. Over the course of the day, the engine began to make some tapping noises, usually when under deceleration. The situation progressively got worse until pulling into our home town in New Jersey it was really rattling. Then, coming up to a red light, which turned green before we stopped rolling, the engine quit. At that point, the starter would not turn the engine over completely. It partially turned it a couple times, then acted as if the starter had no torque. Battery and everything else electrical was fine; it was night now and we had to keep the lights on in order to prevent ourselves from becoming roadkill.
Towed the van home, and let it set. Once it cooled off, I could start it again, but it was not happy. Loud rattle, but not the same one caused by the tensioner/guide failure - which was repaired by the Nissan Dealer over a year and over 20K miles ago - long enough to be out of warranty for the repair.
The sound includes some periodic metallic screeching, like bolts are backing out of something and hitting something else... this kind of sound I've heard when bolts holding the flex plate to the torque converter partially backed out on our old Dodge Caravan.
The screeching is not rhythmic, and there is a loud rhythmic tap too... among noise that sounds more like a typical timing chain rattle.
Help? What should i look for, or just tow it back to the dealer and beg for mercy?
Thanks.
