Timing Chain Rattle
Francox23
My Ka24de is currently giving me that "tin can noise" i wanted to know if running the car with a looses timing chain is damaging at all i m currently like 150 miles from home and have to drive back thanks
WoolyS14DET
Car: 1998 Nissan 240sx w/SR20DET
Are you sure you got enough oil in the motor ??
Francox23
plenty of oil is this damaging the engine?
assassin7420
Car: 1996 Nissan Silvia
1995 Nissan 240sx (daily)
Pop your valve cover, The upper guide might of broken.
I drove my old 240 a good 80k in on year all with a little timing chain tap, Ran fine. As long as its not loose to the point of jumping teeth you should be fine to make it home.
