I am so grateful for the solution that Jim M has posted in this forum. (as well as the others) Putting a 1/4 inch "cap" or extension on the tensioner piston saved my bacon.
I found this solution on my third time around, opening up the timing cover and scratching my head, cleaning out the oil pressure feed port, installing new main and rod bearings from below, heavier oil, etc. All the things I found mentioned, but only the tensioner-piston-extension trick did it.
I also took one further step and removed the exhaust side chain guide completely. Gone. Other posts said Nissan mechanics were doing this a long time ago and with a taught chain I felt I could run the risk of the experiment. Anything to quiet things down.
Final item I tried was to tighten up the tension on the tensioner spring just a hair by installing a spacer (a small nut) inside the piston itself, held in place by the spring.
I am very happy with the result so far.
May have been not required, but I did epoxy the spacer-cap-extender onto the end of the tensioner piston itself. My thinking was that I did not want the piston to be able to retract far enough for the "cap" to fall off.......It could be overkill but it made sense to me in the middle of this surgery.
Thanks Jim. You are a lifesaver.
anyone with similar troubles can contact me at
[email protected] if they would like to ask questions and I will be glad to help. Jim also has the extension part perfected and he was more than willing to help me.
