s13EastTN »
https://forums.nicoclub.com/s13easttn-u15057.html
Fri Aug 06, 2004 10:01 am
Wow, I beleive your estimates are a bit low.
If you only get the bottom chain, then it may be around 80ish depending on where you get the parts.If you get both chains all tensioners cam sprockets and everything else, you are looking at about $250 for parts from autozone or $400+ nissan parts.
Most shops charge anywhere from 800 to 1200 dollars to do this install, which includes parts and labor.
It is a 9 hour job to someone out there, but for me it was a very long process but I finally got it.
