timing chain question (ka24e)
sloweighty
Car: sileighty
has any ever heard of a timing chain break or snap in a ka before. And my tensioner is going out because when i start up the engine when it is cold it would rattle for 2 seconds and then it would build pressure and then it would sound fine. Should i replace just the tensioner or should i just do my whole timing kit?
carmo
Car: 92 Accord, 90 Civic, 89 240sx
Replace it all if you're going to be in there anyway.
kraf
Car: sleepy s13 hatch
exactly what the last guy said! if youre gonna be in there anyways it only makes sense to go ahead and change out everything so then there wont be another problem for a while.
lilpiton
Car: 92 hatch
kraf wrote:exactly what the last guy said! if youre gonna be in there anyways it only makes sense to go ahead and change out everything so then there wont be another problem for a while.
I tried to find a write up on how to change the timing chain, well everything and i couldnt find it. anyone can lead me to a write up?thnks alot if you can do that for me.
Airmanspecial
Car: 1990 240sx
the chiltons manual is pretty detailed....i just got done with mine, i pick up a timeing set and gaskets for about 100 bucks. I did manage to take the timing chain cover off withou removing the oil pan....i just removed the four bottom bolts and and gently pryed it loose comin out as strait as possible...plus nows a good time to replace your broken chain guide..caue if its rattleing..im sure thats not helping either...the new OEM replacement set has all that stuff.....tensioner, tension rod, guide and sprockets. the gasket set(SEPERATE) had oil pump seals and front seal
kraf
i havnt changed my timing chain yet (supposed to do it today) but these are the directions im using. im gonna try to take pics while i do it and make a step by step with pics. if i get that done before you ill send you it.
http://www.nicoclub.com/articles.php?id=168602
MikEEEx3
Car: 89 240sx
i did my timing chain and its a b**** i must say. i got my directions form all data. the 240 has a recall on the timing chain glide. mine was bad enough to rud throught the water pump ducts
pionekss14
Car: 95 240sx
YEA IM CHANGING MY TIMING CHAIN TO RIGHT NOW BUT I WOULD RECOMEND JUST BUY THE WHOLE TIMEING KIT AND A NEW WATER PUMP AND THAT SHOULD DO THE TRICK
