DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon May 12, 2003 2:11 am
http://www.nissaninfiniticlub....12551Much has been written in the past regarding engine failures and how immediate failures from broken guides are, in fact, rare compared to eventual failures of engines whose guides are in the oil pan. Unfortunately it seems a lot of that info has been lost in server moves.
Without knowing the actual geometry of a cam lobe (beyond lift), I can't really guess how much less air is going in and out of the cylinder. I would guess that emissions are impacted, probably increased HCs from running too rich. Valve overlap would be the same, as would spark relative to piston. Retarding the valves would appear to have the same impact as dropping the CR while increasing fuel. Incorrect timing should show up in a compression test, especially if one head's compression was a lot different from the other head's. Allowable range is from 142-185psi I think, with small variations allowed across cylinders.
