JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Tue Sep 21, 2004 5:40 am
If your car is stock, you should not need to adjust the idle. All 240SX's are know for their coolant temp sensor connection corroding and sending a faulty reading to the ECU, which creates an overly rich condition, which would cause hesitating and backfiring and smoke from the tailpipe. Check this first, i would bet it has some corrosion on it. Also, wiggle the wire coming off the MAF sensor, you might have shorted it when you cleaned it.
But the thing is, if your chain isnt properly tensioned, then the camshaft is going in and out of time with the crank, which would cause irradic idle and hesitation until there is enough tension to keep the two in time with each other. I would look harder into the tensioner problem before i started messing with the idle at all.
Let us know what happens.
