Danny14gnx wrote:more less how much tension should be on the chain cause my 240 makes a noise that sounds like the chain is stretched
This is a very uncommon thing to happen. All Nissan chain driven engines have an automatic tensioner for the timing chains. There is no way to adjust it, at all.
The only thing that can happen is the piston of the tensioner can stick due to sludge build-up and can cause the chain to not have enough tension, which would cause the chain to slip. And with most Nissan engines, if this happens, you will more than likely have a valve or two or most strike the pistons. New engine is needed after that happens........
