180fan »
https://forums.nicoclub.com/180fan-u3602.html
Fri May 21, 2004 6:08 pm
on the de's there's an upper timing chain, you can take that one off, the lower one is the one with the other sprocket that's hooking them up together. Not exactly sure if that sprocket bolts to the head or to the block but it shouldn't be too hard to have a look when loking down the valve cover.
