Timing Chain Problem
240sxrunner
Car: Auto and Computers
Ok my timing chain is really lose i took off my valve cover and tryed to look at it and it was so lose i could jiggle it around. what may be the problem one side is lose but the othert side is not ????
240sxrunner
i have my throttle body and plenum off now and working my way on taking this whole engine apart does nobody know the answer to this?
elbles
Car: 1990 Nissan 240SX SE Fastback
What side is lose? The passenger or driver side? If it's the passenger side, it could be a "frozen" tensioner, not forcing itself against the chain to create tension. If it's on the driver side, the problem could be, and likely is the same. :-) With that said, I've had some timing chain noise in my 1990 240 with a freshly rebuilt engine, pulled the valve cover, and noticed a bit (not much) of slack in the chain. I gather you have more than a "bit", but nonetheless . . . ideas for fixing it? Maybe some WD40 or carb cleaner on the tensioner, sometimes that helps "de-gunk" things . . . other than that, pull the front cover and do the chain, something I'm comtemplating doing to get rid of the noise entirely. Hope that helps.
