180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed Sep 14, 2005 10:01 am
Don't move a thing. Rotate the chain around till you get the keyways pointing up and the colored link matched to the punchmark on the cam sprocket. That will verify if your chain has moved or not. If you're hearing a rattling, check to make sure all the bolts at the front are still there and that the guides are tightened down. You'll have to pull the front cover for this.
First thing is first though, are you sure the noise is coming from the chain? It could also be some left over plastic bits from when your guide originally busted in the oil pan making the ruckus. Post what you find before going through the pain of basically redoing a chain job.
