TIMING CHAIN NOISES .??. 3 VIDEOs W/ SOUND
FoxFire
Car: 90 vg30eT 240SX, s12 vg30e
any ideas??
i already know that almost all sohc 90 240s have timming chain problems
is this noise the timing,slipped tooth,ignition problems,fuel related,or combo
if it is the chain, had long do you think previous owner drove around like that for it to get that bad
or can the guides just break with one hard slap of the chain?are they broke from pic shots?
did compression test 180psi across the boardIgnition is finefuel is fine (might be rich?)
Google video
Moving timing chain with handhttp://video.google.com/videop...43667
up close timing chain while kicking over w/out fusehttp://video.google.com/videop...45544
Bad noises 600rpm idle to 4G revhttp://video.google.com/videop...81241
Sleepy_Steve
Car: I dream of a 240sx
I cant help you at all with you problem, But maybe me giving props for a nice amount of effort going into a post can act as a bit of a bump for ya.
DaydreamDrifter
Car: 90 240sx 00 Altima
Your timing chain has ate through the right ride chain guide that was from the factory, all plastic. Now the chain is riding against the water passage on the engine's front cover that leads to the water pump. Myne was doing the same and nearly reached the water! I decided to go HC head swap and when doing so I found a bunch of plastic in my oil pan!
Emc-Icon
Car: 1990 240sx (in the middle of ka24det swap)
um.. it sounds like its misfiring..check spark plug wires one by one (pull them off while engine is running.. )also.. the timing chain/guides MUST be replaced...
and for the peace of heart, i would consider replacing the front cover too... (hell if you pay for the shipping ill send you an extra front seal i got lol)
heres a link for ya... http://cgi.ebay.com/ebaymotors...wItem
if you dont take the time to do it right.. when will you find the time to do it again?...
benemorius
Car: s13, s13, eg, e36
I don't see or hear any definitive problems with the timing chain. The guide appears to be intact, though I can only see the very top. It's normal for it to be loose while the engine is stopped because the tentioner is operated by oil pressure. It's hard to make very much of the noise it makes while running. Can you do another video and walk around the car/engine with it running so I can get a feel for where it's coming from and hear what it sounds like better?
FoxFire
Ok ill make a vid with it kinda idleing also its running on 3 cyls cuz i take pulg number 4 off does nuthing to change the sound and the engine rattles back and fourth alot
