AlanAZ »
https://forums.nicoclub.com/alanaz-u260658.html
Mon Mar 09, 2020 4:49 pm
I had an idle vibration in my QX4 two and half years ago (135K miles, sketchy maintenance history) bad enough that automotive knowledgeable friends would comment on it, and we'd a discussion about engine mounts.
That was until I cleaned the engine with BG EPR 109 (20 oz for 20 mins), to address the oil consumption issue and restore compression. Immediately changed oil and filter after with Valvoline Maxlife hi-mileage full synthetic 5w30. Old oil came out BLACK (all other vehicles I have done this on, the oil came out brown), as a precaution, I changed the filter again after 500 miles. It did restore compression and power greatly, reduced oil consumption somewhat, and idles much more smoothly -- I have no thoughts of changing the mounts. There was a price to pay for all this goodness, prior it didn't leak oil on the ground, now it did. I immediately replaced the oil cooler seals, and I now see oil dripping from the lower rear corners of the valve covers. My thinking is that it removed sludge that prevented these leaks, but also removed it from small oil passages that prevented full lubrication and caused vibration.
After I replace the valve covers, at the next oil change, I plan to run another dose of it (~3.5 yrs after the first, and only because the oil came out so black.)
