mercuriocaro »
https://forums.nicoclub.com/mercuriocaro-u59618.html
Sun Mar 23, 2008 7:34 pm
i have a '05 QG18DE, i was changing the spark plugs a month ago (without the engine completely cooled) and ended up stripping and snapping the number one spark plug halfway in its hole.. so i ended up pulling the head, drilled out the plug and threads, put new plug threads in, replaced the gasket and bolts, and now am encountering a problem with the timing marks, as the FSM for the 04, 05 AND 06 show a diagram for the timing alignment to have two blue links aligned with the exh. and int. cam sprockets and 1 yellow ligning up to the crankshaft sprocket, but my chain only has 1 blue link which aligns with the exhaust sprocket mating marks at TDC , but for some reason i did not mark the intake cam sprocket alignment mark on the timing chain itself correctly and now can not even find the right lilnk that the intake mating mark corresponds to, i know its off as my car wont stay running and you can hear and feel a misfire. the fsm has link intervals for the QG25DE but alas, no 1.8 info on that . anyone have a pic of a properly installed chain at tdc so i can count the links between mating marks on the sprockets? or does anyone know at TDC how many links between mating marks? thanks in advance.
