timing chain install, timing, where to have th gears?
InfamousSilvia
Car: BMW
Im putting a new timing chain kit in my S13 SR before I install it.
I was wadnering if someone could tell me where to position the crank/cam gears when installing the new chain, and how to time it in with the CAS or give me a link to a diagram, any help would be greatly appreciated!
Thanks,Brian
180fan
Car: 89 fastback
Intake cam at about 11 o'clock and the exhaust cam about 1230. Don't tighten down the cam until you've got the links lined up though.
http://store1.yimg.com/I/phase...66541will walk you through the CAS.
Nismo1182
Car: Z06
well theres a tensioner on the side of the block that once you unbolt it, it makes putting the chain back on 10000x easier. Even with the cams bolts on.
