Rev_D21 »
https://forums.nicoclub.com/rev-d21-u4222.html
Sat Aug 28, 2010 6:09 pm
You don't have to remove the head if you bend the front lip of the pan enough for the front timing cover the slip off. I did mine 2 years ago except I decided the drop the pan to retrieve the broken pieces of guide floating in the oil. Cost me a few hundred in parts but that's because I went ape-s*** replacing anything I could find. Water pump and T-stat a must. Also replace your belts, flush your radiator good inside and out. The worst part is getting the oil pump and dizzy sync'd correctly. It pays to have someone hold the dizzy rotor in place as you feed in the oil pump and spindle. Get 2 oil pump gaskets! You will F one up no doubt. TDC is a must before you rip it apart. Turn the engine by wrench TWICE to make sure the chain links line up before hitting the key in the ignition. Have fun!
