onecrazyfoo4u »
https://forums.nicoclub.com/onecrazyfoo4u-u42462.html
Wed Oct 03, 2007 8:11 pm
I think I have this same problem with the guides rattling. How do you know that's the problem? I have the consistant rattle, only from 2400-2800 rpm's every time. Doesn't matter if it's hot or cold, it will also make the rattle sound everytime inbetween shifts. Is this the timing chain hitting the guides, or would it be a tensioner?
Is the upper guide easy to remove? Do you just pull the valve cover and take it off, or do you have to mess with timing? I saw the writeup for a ka24 timing chain service, is it basically the same for sr20's too? Thanks!
