Skidmark »
https://forums.nicoclub.com/skidmark-u35273.html
Mon Dec 12, 2005 3:45 pm
Well, it sounds to me like your chain and/or tensioner are the problem, and this is why I say that... The noise you described is pretty close to what a ratlling timing chain sounds like, and it make sense that it would go away at high RPM, where the momentum and centrifugal force is keeping it pressed firmly against the guide. I would suggest the prybar tensioner test that tonynalli mentioned. If the tensioner compresses too much for comfort, then replace it along with the chain, make DAMN sure your timing is right, put it all back together, and fire it up. If the noise goes away, problem solved. If the noise doesn't go away, then maybe your rod bearings are bad. Luckily, you won't have to un-do anything you just did in order to fix those as well. Timing chain probably isn't too advanced as long as you have a way to make SURE your timing is right when you get done, but I wouldn't recommend replacing your own bearings without help. Oh by the way if you want to compression test your motor, you can buy the gauge at any auto parts store, anywhere from $20 to $50. Just remove a spark plug, screw the gauge into the hole, unplug your fuel pump and turn the motor over a couple times with the starter. 150-170psi is a good healthy motor, anything drastically less than that could mean any number of serious problems. Good luck.
