R240NA »
https://forums.nicoclub.com/r240na-u1367.html
Sun Jan 19, 2003 1:06 pm
The second one is nearly identical, but attached with 10mm bolts. It's located behind the upper timing cover, right beside the distributor inlet. Pull the distributor, and then take out the six 12mm bolts and three 10mm bolts, one is hidden underneath the distributor area, that secure the cover and remove it. Be sure to seal it back up good when you're done.
