Timing chain gone bad???
SrS13
Car: 1990 Fastback, 1993 Convertible Coupe
Every time I set my timing back to where I want it. In a couple of days it will be all retarded again. I tighgten the CAS properly and I unplug the TPS sensor every time I redo my timing. I'm thinking my guides are worn or maybe I just need to replace everything?
Help me members!!!:help
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Hmm, does the CAS itself rotate from the point where you tighten it? Have you pulled the cover to check if the chain marks skipped a tooth or two? Need more info then that..
SrS13
no I have not pulled the cover off.
Could you or someone explain that process for me.
