Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Nov 11, 2005 9:05 pm
180, maybe i'm just tired and the coffee really is not having any effect on me, or that just didn't make any sense.
But to answer the original question, I recommend that you removed the whole upper oil pan. The reason being is that liquid gasket maker is used to seal the upper pan to the block and front cover. When you pull the front cover off, you break the seal of the upper pan. If you just simply slap more gasket maker on, it doesn't make a continuous bead anymore and will probably leak where the new gasket maker meets the old gasket maker.
As far as the oil dipstick tube, remove it. All you need is a bladed screwdriver, or preferably a prybar, and a hammer. Then tap away at it from the bottom to knock it out of it's hole and just put it off to the side.
And to help save you some time and trouble later on, reprime your oil pump by putting some petrolium jelly in the pump gears. It'll help keep a prime in the pump so you don't have to worry about building pressure when you restart the car. Plus the jelly will dissolve into the oil and you won't have to worry about it again.
Finally, when you're reinstalling the front cover, don't put the oil pump spacer on the crank nose. This way you have some play room to put the front cover on and won't destroy the part of the headgasket that sticks out over the cover. Then you can mess with the pump gear until it lines up to allow you to slide the spacer on.
