When you say the section of the engine underneath the valve cover, do you mean the front cover over the timing chain or an actual part of the head? Anyway, I can't see how the chain breaking couldn't result in bent valves, but perhaps I'm wrong. I'd definitely open it up, but I'd wager the engine is toast.dangrizzly wrote:Recently my timing chain busted and broke through my valve cover and the section of the engine directly underneath the valve cover (when looking at the engine from the front where the fan is.
