timing chain and head gasket
nathanmoris
Car: 1992 300zx
i have a ka24e timing chain that broke and i was wondering if it was just a straight replacment or becuase it broke i have to check other things? i also was wondering what causes loss of power.. the head gasket was recently replaced and after that change it loss power. the compression in all cyclinders are fine. could it had been a bad head gasket replacement? any help would be great thanks jon
rotorimp
Car: 02 Xterra, 60 IH Metro
Nissan chains do not break that often and is most likely related to the head gasket replacement. If you experienced a loss of power right after the hg change then the timing might have been off. How are you able to test compression if the chain is broken? If the chain did break then most likely you have bent valves. Are you sure that the chain is broken?
nathanmoris
Car: 1992 300zx
im sorry i should have word it correctly.... the chain it self didnt break but the timing chain sproket on the crank broke off where the chain is connected.... does this still mean that i need to replace valves since i bent them or could i just replace it and ill be fine thanks jonathan
180fan
Car: 89 fastback
won't know till you pull the head.
nathanmoris
Car: 1992 300zx
is it just a visual thing to see for bent valves or do i have to take apart the head more to see the valves? thanks jonathan
180fan
Car: 89 fastback
just pull the head and if you see scoring on the pistons that'll be another clue. remember to rotate the cam as well. or with the head still on, pull the manifolds, and loosen the cam towers so all the valves should be in a closed position. with compressed air, shoot it through one side of the head. if air passes through to the other side, you've got a leak.
rotorimp
Can you still rotate the motor? I have also never seen that sprocket break. 180 is right--tear that head off and see whats going on in there.
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
hold on. I thought the KA24E was a non-interferance engine. So even if the chain broke, the piston shouldn't hit the valves. Please, correct me if I'm wrong.
rotorimp
They are DEFINITELY interference motors--
480sx
Car: 1996 Pearl White 240sx
For sure lol, your wrong. A jeep guy tossed that term at me the other day and i was trying to throw around the idea in my mind..
What OHC motor ISNT an interference motor...
rotorimp
Since you asked--mazda miata
nathanmoris
Car: 1992 300zx
so since my timing chain broke while i was on the fwy i problay need to the head off and change valves right
rotorimp
Yes.
nathanmoris
Car: 1992 300zx
hey, i dont have the money to get a ka24e head rebuild or a new one.. so i was going to buy a used one from someone. i was wondering what i could check for the i can see i guess to make sure its ok if theres anything thanks for any help jonathan
rotorimp
Most importantly make sure that the head is flat--go to a machine shop they will not charge much. then follow the procedure in the fsm. Good Luck
nathanmoris
Car: 1992 300zx
Thanks
jaytv1019
Car: 1995 240sx w/redtop swap
I have 2 KA heads. Let me know if you need one.
nathanmoris
Car: 1992 300zx
yeah i do ... are they in good condition and everything and how much you want for them if so and where are you located
nathanmoris
Car: 1992 300zx
hey so since the chain broke i did mess up the valves but the small block and pistons and all that is fine right? cause i gonna try to get some work on it done but i dont want to spend money on it if the pistons to are messed up thanks for the help
rotorimp
You will have to pull the head--I have seen only 1 valve messed up and I have seen holes in pistons. So pull that head and see what is damaged.
nathanmoris
Car: 1992 300zx
i got a bent valve after pulling it and the pistions look good to me but really what do i know about pistons... nothing..... theres no movement from side to side and no damage to the cylinder and a little dark pistons but i think thats from combustion.... anything else im missing about the piston check... thank alot rotorimp you know a lot and i am very greatful for all this info thanks
nathanmoris
Car: 1992 300zx
hey, im having trouble removing the intake manifold from the head, i made sure all the bolts and plates are off the head but when i try to split it i dont nreally seem to be getting it apart.... is it just really hard or is there a secret to this i dont know thanks
180fan
Car: 89 fastback
give it a wiggle. Did you also get the hoses and wiring off?
wa-chiss
2005 Toyota Sequoia
How many bolts did you remove? There are 7 IIRC. Two run through the manifold. It took me a while to figure it out. Yeah I felt dumb.
nathanmoris
Car: 1992 300zx
Thanks Everyone finally got it off..... since i had a bent valve ... would that cause the loud ticking, knocking noise under the valve cover ... thanks jonathan
rotorimp
Let us know how it turns out--post up some pics. so we can see the carnage. Good luck!!!
pmb434
Car: 1992 NISSAN 240 SX
Just had the same thing happen to my ka24de broke the cam bent all the intake valves still trying to get it together good luck my pistons had some marks on them but was ok if you learn short cuts or good info please post it .
