dubstyles240 »
https://forums.nicoclub.com/dubstyles240-u12594.html
Thu Jan 29, 2004 8:50 am
My KA had this after i put it in my car... it was rattling really bad. Just take out your plug wires, unbolt the valve cover and remove it (you might want to get a new valve cover gasket, I didn't). You can see the timing chain... and at the very top of it, there is a little metal plate, maybe 2 inches wide. 2 bolts hold it on. Take it off, put it in the trash can. Put everything back together, and that should take most of the rattle away. Mine still does a little bit, but its not too bad once it warms up.
That plate you are throwing away is just a guide, it is very redundant, and not needed at all.
