float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Feb 21, 2007 9:20 am
the problem is that if it is as far off as you say it is, it's quite possible the valves are bent. You can try and fix it, but it may be too late. It won't hurt to try I guess.
Just a note, although it can be done by yourself, it's MUCH easier with an extra set of hands.
There is a mark on the lower timing cog and a mark (more like a notch) on the oil pump. With the motor at TDC those should be aligned.
There is a mark on each one of the cam pulleys and a marks on the back plate behind the cam pulleys. It is easier to line these up if you remove the valve covers and get a big pair of vice grips or a cresent wrench on the camshaft. There is actually a spot on there that isn't rounded specicically for that reason. I also use small vice grips to hold the belt to the cam gear once I get it in the right place.
