Timing Belt Time - Are these parts good quality?
stevesa
Car: 1998 Infiniti QX4
I have a 1998 Infiniti QX4 that is overdue for it's timing belt change. I found this kit for $239.10. It seems fairly complete. The only thing I see missing is the bypass hose. I'd like your expert opinion as to what else may be missing and the quality of the included parts. Thanks!
--- This kit fits ---
1997-2000 Infiniti QX4
( 1997 1998 1999 2000 )
All 2WD & 4WD Models with 3.3 Liter / V6 / VG33E
Includes The Following Brand New Parts:
Quantity Part Manufacturer Part Number
1 Timing Belt Mitsubishi 13028-0B785
1 Tensioner Roller NSK 13070-42L00/V5001
1 Tensioner Spring Nissan 13072-7B000
1 Front Crankshaft Seal THO 13510 77A10/50B10
2 Front Camshaft Seals NDK/Stone 13042-D0101
1 Water Pump Atsugi/Paraut 21010-4S10A
1 Water Pump Gasket Atsugi/Paraut Included
1 OE Thermostat Nissan 21200-V7206
1 Air Conditioning Belt Bando 5PK-1280
1 Alternator / WP Belt Bando 6PK-1065
1 Power Steering Belt Bando 4350 / 3340
fueler
Car: 2 Nissan's
2 BMW's
the mitsubishi (or is it mitsuboshi) timing belt is the best since they are the same company that makes the OEM nissan belts. So the belt you have on there right now is the same brand.
Thats also the same one i use.
from a quick glance, that list looks perfect.
VG33QX4
Car: 2000 Infiniti QX4
I am pretty sure that is all oem stuff, go with it
stevesa
That's what I wanted to know. Thank you so much for your help!
